Re: wire and pipe
Bryan, why would you think this may be trying to "beat" the code? You admitted that the code doesn't say it can or can't be done. So with this said, if you adhere to all other wiring methods that might pertain, and do it in a workman like manner, this would by no means be wrong or an effort to "beat" the code.
If the NEC had to address every item as to whether it can or can't be used or done, we would need a trailer to carry it with us.
Just because the NEC prefers to have listed items used, are you going to look high and wide for listed and approved screws to mount your boxes or supports? The NEC doesn't say what types can or can't be used.
The bottom line is, if it is done in a effort to be safe, and the wiring methods used, are in compliance as far as what is specifically "shall or shall not" then we have met the intent.
So, if we are called as an expert witness in a suit, we would evaluate what has be done, then apply the NEC and common sense to our testimony.
Roger
