408.55 Wire-Bending Space Within an Enclosure Containing
a Panelboard.
(A) Top and BottomWire-Bending Space. The enclosure
for a panelboard shall have the top and bottom wirebending
space sized in accordance with Table 312.6(B) for
the largest conductor entering or leaving the enclosure.
Exception No. 1: Either the top or bottom wire-bending
space shall be permitted to be sized in accordance with
Table 312.6(A) for a panelboard rated 225 amperes or less
and designed to contain not over 42 overcurrent devices.
For the purposes of this exception, a 2-pole or a 3-pole
circuit breaker shall be considered as two or three overcurrent
devices, respectively.
Exception No. 2: Either the top or bottom wire-bending
space for any panelboard shall be permitted to be sized in
accordance with Table 312.6(A) where at least one side
wire-bending space is sized in accordance with Table
312.6(B) for the largest conductor to be terminated in any
side wire-bending space.
Exception No. 3: The top and bottom wire-bending space
shall be permitted to be sized in accordance with Table
312.6(A) spacings if the panelboard is designed and constructed
for wiring using only a single 90-degree bend for
each conductor, including the grounded circuit conductor,
and the wiring diagram shows and specifies the method of
wiring that shall be used.
Exception No. 4: Either the top or the bottomwirebending
space, but not both, shall be permitted to be sized
in accordance with Table 312.6(A) where there are no conductors
terminated in that space.
(B) Side Wire-Bending Space. Side wire-bending space
shall be in accordance with Table 312.6(A) for the largest
conductor to be terminated in that space.
(C) BackWire-Bending Space. Where a raceway or cable
entry is in the wall of the enclosure opposite a removable
cover, the distance from that wall to the cover shall be
permitted to comply with the distance required for one wire
per terminal in Table 312.6(A). The distance between the
center of the rear entry and the nearest termination for the
entering conductors shall not be less than the distance given
in Table 312.6(B).
