controlsdude
I'm working on an industrial design where I have a single phase 480VAC to 120VAC transformer, fed from a circuit breaker in a panel. The feed goes from this panel, to the transformer. The secondary of the transformer, single phase 120VAC, goes into a different enclosure which has a disconnect on it.
I know that per Code, we cannot disconnect a Neutral conductor. So the 120VAC wire on the bottom of the disconnect would be Red. But... the Neutral wire... Is it OK to be just white, or does it need to be white with orange? Technically, it still has a live connection to a device, namely the secondary of the transformer, and I would not consider it "safe".
If you need some more info let me know. I feel like we do this circuit all the time, but for some reason, it stuck in my mind this time lol.
