Danegoodwin
New User
- Louisiana
- Electrician
Question. In relation to the AC rule found in 240.4 (g). Since I mostly do residential. I use the 60 degree column for wire running from the interior panel through the residential structure to the disconnect and then 75 degree table for the whip. Does that sound correct? And then am I able to use the chart/ampacity from 240.4 g on residential wire? Or does this rule only apply in commercial setting using THHN?
