madferraristi
When connecting, say, a #12 STRANDED wire to a duplex outlet that has screw terminals only, I was taught, years ago to strip the wire about 11/16" and then cut an additional 3/16 of insulation and push it to the end of the wire.
Then when the wire is wrapped around the screw and it is tightened, the wire can not spread out and stays under the screw.
I was told recently that this is not acceptable and a crimp-on terminal MUST be used for stranded wire under a screw head.
TRUE OR FALSE???
[ March 17, 2004, 10:30 AM: Message edited by: madferraristi ]
TRUE OR FALSE???
