wire length help
pntdxtr
Please help , i am trying to figure out some leftover wire on reels i have on the jobsite . The reels are #6 thhn and want to calculate the length to see if i need to order more ..Thanks
jusme123
did you look at the wire to see if it has the length numbers on it (I know its obvious, but just checking)?
nhfire77
Cheaper version would be the triplett 3271 TDR. ($152 on amazon) You have to calibrate it to the wire you are measuring based on a known length of that cable.
Megger has a nicer $900 tdr as well
LEO2854
Esteemed Member
You can always pull them off the reels and see how log they then just roll them back up again ,or have your helper roll them up..:lol:
infinity
Weigh a new full reel of the same size and manufacturer, then weigh the used reel. Find the weight to feet ratio and do the math.
ActionDave
You may not even need to get too deep into the math.
A new 500' reel of #8 weighs 31 pounds. So if my partial reel more than fifteen pounds I know I have at least 200' available. That may be all the information I need.
tkb
Measure the circumference of the reel and count the amount of times it wraps the core.
Wraps x circumference = length on reel
ptonsparky
Ohm it out, then divide by .00051 :roll:
$2200 to $3200 for a Micro ohm meter makes the other options pretty reasonable.:jawdrop:
Weight or measure once and count the wraps. If we aren't sure, it is cheaper to have new rolls on hand than to come up short on a long pull.
You haven't kept track of what you have pulled in so far?
scook56
Approximate Length
Approximate Length
As tkd stated, Measure the circumference of the reel and count the amount of times it wraps the core.
Also: C = Pi * D: Circumference = 3.14 * Diameter. Approximate length for hand coils, too.
Hv&Lv
Yea, I was just throwing that out there for a chuckle. Didn't think it would even be considered...
Seriously, I have taken my reels to the supply house and had them spool it off through their counter for the lengths. Usually less than 100 feet though.
Of course, I bought these same reels from them, and they know it.
handy10
Without being too specific about what is wrong with the information given so far, I suggest that the problem is more complex than simple formulas will give. An exact formula would be quite difficult, but there is some possibility of a reasonable approximation. Here is some notation:
t=radius of the wire and its insulation
Ri = inner radius of the spool
Ro = outer radius of the spool
First assume that the flanges of the spool are so close together that the wire will look like the way sailors coil rope on the deck of a ship(flat coil). To make such a coil, one would start at the core of the spool (the inner radius Ri) and and make n turns to get to the outer edge of the flange (the outer radius, Ro). Then we can find the number of turns to be
n=(Ro-Ri)/t
The first time around the core requires 2pi(Ri+t) amount of wire, since the radius of the second turn has been increased by t, the second turn will require 2pi(Ro+2t) amount of wire. The last time around will require 2pi(Ri + nt) wire. If all of the turns are added, the formula I get is
Wire on one flat coil = 2n(pi)(Ri + n(n+1)t)
To complete the calculation, you must know how many flat coils are on the spool. If D is the distance between flanges then
m=D/t where m is the number of flat coils.
Therefore, the total length is
Total = m(wire on one flat coil).
Of course, wire does not wrap on a spool exactly like a bunch of flat coils. The second layer on the spool will fall in the space between coils of the first layer, think of three tangent circles. For this and some other reasons, the formula is only an approximation. However, all of the information required can be obtained with a ruler or tape measure.
K8MHZ
Don't forget Murphy's Constant.
In applied Murphology, Murphy's Constant is 0.97.
That makes the math simple. You just multiply the amount of spooled material you need by 0.97 and that is how much will be on the spool. So if you need 100 feet, there will only be 97 on the spool.
Cow
So Handy10s very fine formula times K8s fudge factor & you got the answer...to short again.
And now the crew is standing around waiting to pull the wire back out and start over. Meanwhile, you could have spent the same amount of money on a meter and had something to show for it....
Just saying....it doesn't take too many man hours for one of these meters to pay for itself. We used to count wraps, but it doesn't make sense financially, when you figure how much time you spend doing it in say, a year or so. Not to mention a lot more of our spools got used up because we knew what we had on them. When we used to rough guess how much was on it, we'd get scared we'd be short and order new spools instead. You can imagine how many leftover spools end up in inventory this way....we've really trimmed back now using a meter.
handy10
Truth compels me to admit that my wonderful formulas are wrong. For starters, the number of wraps and the number of layers, must be obtained by dividing by the diameter of the wire, not the radius. In retrospect, I like the Murphy's law the best. A variant is to measure the length of wire required and subtract 10' to find out how much is on the spool.
