danbel57
- Westchester, IL
After adjusting for correction factors in sizing a wire to the load, you frequently end up with a wire that has a greater amperage rating than the circuit breaker protecting that load. According to the code the amperage of the wire has to be protected by the circuit breaker. However, if you have to increase the circuit breaker to protect the wire, you are no longer properly protecting the load it serves. Any thoughts?
