I had a customer that wanted another receptacle in a room that only had two. I told her that wire mold was the easiest/ cheapest way to go. They had K&T wiring with no ground. So I figured I'll put a GFI in a wire mold extension box and label it no equip ground and run the metal wire mold over to my new receptacle, which would be the load side of the GFI, and label that no equip ground also.
Then I thought.... Can I run this metal raceway with no grounding means? even though its GFI protected? I did not want to do that. Lucky for me the other receptacle in the room had a ground, so I wire molded over to it to pick up my ground.
I have seen that NM wire mold, but have never used it.
What would you guys have do in this situation? Can a guy run metal raceway with no grounding means attached to it? What if the circuit is GFI protected?
