nevsquare said:
Hi forum members: as a helper I sometimes see a wire nut connection inside a breaker panel where some one came up short.
Welcome to the forum and the trade.
The other day I worked with an electrician that did it and he said it was ok because a connection needs to be inside a box and the breaker panel qualified as such.
First you need to think like the NEC, it would be imposable to put a splice in a
panelboard.
Per the NEC definitions this is a panelboard as covered by Article 408, it is missing only the dead front.
This one may be much larger then what your used to but to the NEC a panel board is only the 'guts'.
Panelboards are generally mounted in a cabinet as covered by Article 312 and
This is a cabinet as covered by Article 312
When you do commercial work you often have to order the parts separately, when you do residential work you normally use a "Load center" which is a manufacturers term for a cabinet, panel board and cover all shipped together.
The reason I am telling you all this is because in order to find the answer in the NEC you need to know where to look.
The electrician you where working with was correct he can make a splice
in a cabinet that contains overcurrent devices.
The rules for doing so can be found in 312.8
