marinesgt0411
- Naples,FL 34110-9285
Is there such a thing as a wire nut rated for spliceing #6 wire?
marinesgt0411 said:the box I have looked at says wire range is #14-#8 for blue wire nuts
just started thinking that I have never seen a wire nut rated for #6 wire.have always used split bolts and just started to wonder why.
going to go do a search of Ideal wire nuts
iwire said:I doubt I will ever by split bolts I just never liked them.
There are just so many other choices many of which are pre-insulated and easily removable / reusable that IMO split bolts are history.
But as far as the OP I would use the Idea 454s that where already mentioned.
sparky_magoo said:I think blue wire nuts fail. I know they fail because I have done too many service calls to fix them. I have been on calls to fix Polaras connectors. The Polaris connectors fail because of corosoin. I have never been on a call to fix a properply slpiced split bolt connection.
