As I see it, the un-capped red and black conductors feed through the box, and the neutral is interrupted by what appears to be a switch loop.Looks like a straight 3-way switch - no feeder? Maybe?
WOW maybe the same guy did this. Same thing, branch circuit in UF feeding the garage, exposed in the basement, no cover, and energized.
Messy to say the least.Wee don't need no steekeen' wire nuts!
Found this today. I'm assuming it's a 120/240 UF feeding a detached garage.
Not only are the two hots bare, but the neutral is connected to a separate NM cable. I'll investigate it more Monday.
Nut from me........we don't use 'em......Well.. at least it's accessible...
hey where did these two yellow wire nuts in my pocket come from?:blink:
Mostly out terminal boxes, receptacles, switches light fittings come with screw terminals.Lucky for us they left plenty of free wire to work with!
"See it works, we don't need one of them high dollar illektrisons!".
