Wire-nuts
Mule
Oklahoma
Hey you wire nuts....Do you twist them to the right or the left?
Hello everyone....Hope you have a Merry Christmas !!!!!
480sparky
Iowegia
PWI?
tkb
MA
They have to be installed by twisting to the right.
That's the way the spring inside works.
In CT there is an EC that has a left handed splice as part of their logo.
I met the owner of that company at a code update class a few years ago.
He said that the only people that pick up on that is other electricians.
Mr.Sparkle
Jersey Shore
Interesting. Would you trust those to connect a water heater or an AC compressor?
I personally do like them and have used the ones that come pre-installed in Halo cans for quite some time without a problem (you have to be sure the factory seated the tinned pigtails in all the way). I also used a ton of them in a house I where the owner wanted all the bedroom and living room outlets 1/2 switched but I seriously doubt I would trust them on any type of load like the ones you mentioned in your post Larry.
scwirenut
water heaters are thats pretty much all I do use the 773's on, I hated twisting the 10&12 together. stressing out the wires, stressing out my carpal tunneled hands, ect. i have done over 100 water heaters and thousands of switches without a single failure. why wouldnt I use them?
you know this is what people would say about wirenuts when "old timers" said soldering was better.
