Re: Wire nuts
The code states that soldered splices must first be mechanically and electrically secure before the soldered. With the application of "wire nuts" or as the code refers to them as wire connectors, do you feel it is better to first mechanically connect the conductors then apply the connector, or will the connector apllication suffice as joining the conductors mechanically. It is my opinion that wire connectors are more for insulation than joining. I have has alot of problems with conductors pullong out of wire connectors, or loose connections in general. Any thoughts?
