Doing an estimate for a customer and want to make sure I'm on the right page and see if there are any other options. Customer wants a generator installed, however from the generator to where the transfer switch will go is 250'. It's a 24KW generator with a 100 AMP breaker. My calculations have brought me to need 1/0 for 100 amps at that distance and keeping it at 3% voltage drop. Using THWN. This would be running in EMT through attic, through a workshop and outside. I've never ran long runs like this as my jobs have usually been small residential homes. I'll take any help I can get, and take any suggestions that you may have. One question that I have is does the 1/0 (If I am correct on my calculation) need to run all the way to the generator, or can I change the size at some point, if so, where? how would I calculate that?
