The first trial I did. 400A and a 1 ft circuit length, and it specifies #14 Cu. :lol:
This is a voltage drop only calculator, if anything at all. It doesn't consider derating, CCC count, OCPD protection, wire/terminal ratings, or even Table 310.15(B)(16) at all. Unfortunately, it doesn't even tell you what the voltage drop is, or the criteria percentage for it, so it is hard to experiment to see if voltage means phase-to-phase, or phase-to-neutral.
