Re: Wire size for an Transformer
I am not sure I understand your question. It sounds like you have a 400 amp single phase panel fed from a stepdown transformer. Is that correct? What is the single phase panel voltage, 120/240?
150 kva is a three phase transformer size, and 350 kcmil is only good for 310 amps, which doesn't seem to match with any of the above either.
If you can post some more info, I'll try to help.
Jim T
