electricalist
- dallas tx
Meter to 400 amp fused disconnect into bldg 24 x 24 j box to 225 amp rated mlo panel. In 24 x 24 are paralled 4/0 . That have nsi type connectors. 4 space.. 1 set feeds existing 225. So 225 / 230 amps. . I understand from meter to 1st disconnect thewire should be sized accordingly and can be split to multiple panels. Can this be done after the disconnect and Iif so will I need to use 4/0 to feed another panel from the nsi connectors or can idownsize if I use a main breaker new panel.
