RBBELEC.
- Grand Forks, North Dakota
Hello everyone, I apologize if this topic has came up before, but to be honest I hope it has alittle bit so someone may have an answer to this problem.
What I have is an apartment building and when I do the voltage drop calculations the wire size becomes so large by half way through the building the it wont fit in the meterstack breaker or the panel. I ended up putting in 225 amp loadcenters in the units due to the wire size because they can handle up to 300mcm SER, but some of the runs are even longer which in turn makes my wire size larger. So if I have a 150 tenant breaker the smallest size SER I can run is a 4/0 and the breaker can also handle up to 300mcm, what does a guy do after you break the 300mcm mark.
We have tried the crimp Pin Adapters with not much luck (to close together). There just isn't enough room in the can for that size of wire and the bending radius is completely over done this way. None of this would really be a problem is the design team of the project would have put the electrical room in the middle, but instead its on the very end of building.
Some mentioned to me the other day that in the code, there is a section saying somewhere that if the breaker is only good for 300mcm(or whatever size) that is all the bigger wire one would ever need for that breaker. if this is true (which I cant see that being the case due to the invention of Pin Adaptors) does anyone know where it is in the code and or does anyone have any other great solutions that may help.
Any info is greatly appreciated. Thanks in advance everyone.
