Wire Size?
jkim780
On Wire size, can anyone tell me what does MCM stand for? (example:600MCM). I know that we use AWG(American Wire Gage) up to 4/0 wire size and Kcmil above 4/0. But every wire manufacturers uses MCM instead of Kcmil. Is MCM same as Kcmil?
[ November 07, 2003, 11:23 AM: Message edited by: jkim780 ]
steve66
Illinois
Engineer
Re: Wire Size?
Yes, kcmil stands for 1000 circular mills. In this case, the k is the standard scientific abreviation for 1000. MCM also stands for 1000 circular mills, with CM being an abbreviation for circular mills, and the first M being a less standard abbreviation for 1000.
I'm not sure how M first got used as standing for 1000. It may be part of the British system of units (feet, pounds, ect). However the bad part is that in scientific notation, M stands for one million or 1,000,000.
roger
Fl
Retired Electrician
Re: Wire Size?
Steve, M is the roman number 1000, so it goes wayyyy back. :)
Roger
charlie b
Lockport, IL
Semi-Retired Electrical Engineer
Re: Wire Size?
It might not go that far back. The french word "mille" translates to "one thousand."
Pierre: C'est vrai, n'est-ce pas?
B
bthielen
Guest
Re: Wire Size?
Notice the capitol M rather than lower case. "mille" is lower case because it is used numerically to represent a fraction of ONE such as milli-volt, milli-meter, etc. The capitol M represents Mega which represents million such as Mega-ohm, Mega-watt, Mega-bit, etc. I can understan the confusion because MCM is also the Roman numeral 1900 so one must separate the first M from the CM to obtain One Thousand Circular Mils.
The mystery continues.
Bob
charlie b
Lockport, IL
Re: Wire Size?
Sorry, Pierre. I had you confused with Marc, the "French Electrician." But I don't speak French either.
Re: Wire Size?
Charlie ,, you are close enough but i am full french and the quote say " it is true or it is not ?? " this is very common french slang word.
the mille is one thousand and french numbers words never use uppercase at all.
and that ok i know it sometime can confuse with someone else name there too
merci, marc
