steam unit name plate : 38 Amp @240 V
What is my wire and breaker size?
Plot twist, the appliance is 400' from the panel.
my question is: do I have to calculate the 125% or it is calculated by the manufacture and it is included with the name plate data?
Don't confuse anyone here into thinking a "double adjustment" is needed.The 125% for continuous will not be included in the nameplate current listing.
If an appliance lists a minimum circuit ampacity instead, I would expect that to take into consideration the 125%. But keep in mind that "continuous" adjustments for branches and feeders generally do not apply to motor loads.
Also for a single load on a branch breaker you may need to consider the 80% of rating rule.
Tapatalk!
