Wire size
bdarnell
Indianapolis, IN
Retired Engineer
Re: Wire size
hardtimes said:
what is the wire size rated for 400 amps
There could be several. This is far too little information. What is the application ? What type cable ? Commercial or residential ? Single phase or three phase ? Inside or outside ? Conduit or direct buried ?
Besides all that, I think this post is in the wrong section. Could one of the moderators be good enough to move it to NEC or Calculations ? Thanks.
paul32
Minnesota
Re: Wire size
Maybe he wants 400A at 12V :D
I suspect a DIYer. If you are still reading it, get a licensed electrician. A 400A service for example is WAY beyond what you should be looking at.
