Alwayslearningelec
- NJ
- Estimator
If you have a 200A disconnect fed from bus tap could you have #1’s XHHW feeding the disconnect? I ask because #1’s are rated for 130A. That is the line side.
The load side of disconnect is feeding a 100A ATS which then feeds a 75kva xfmr,
From the 200A disconnect switch to the ATS and ATS to 75kva xfrmr is also feed with #1’s. Does that make sense? Thanks.
