Brandon Loyd
Have you ever heard of de-rating wire (THHN) down from the 90 degree chart in 310.16 to the 75 degree chart because the lugs on a breaker are rated at 75 degrees? I my mind, a 225 amp breaker with 3/0 THHN is perfectly accepted and the wire is protected even if that breaker happened to load up to 225 amps.
