KarlS
- Houston, TX
I have two questions. Does anyone know where in the NEC that its stated you cannot splice wire in a panelboard? The panel is one ckt short and have stated you cannot splice into another ckt in the panelboard. I know this would be bad practice to start with but the powers above me are pressing to do this unless I give them a direct answer why not. Also, I cannot find any place in the NEC that prevents me from placing 2 wires on BAB Eaton panelboard type breaker. Checking with Eaton I see it lists (1) wire per connection but does not directly state you cannot double up the wire on a termination.
Thanks for the help in advance.
