wire standard
ponder
New member
I know that the NEC standard for 16 awg wire is 8 amps but what if the voltage would not exceed say 32 volts dc would the current rating be the same or would it go up? If does increase where do I find out what is acceptable?
bennie
Esteemed Member
Re: wire standard
When you deal with low voltage it is the resistance, not the ampacity, to consider in your design.
