Re: WIRE TABLES
There is an added difficulty here: Much (most?) metric cable is designed for 70C, not 60C or 75C like the AWG cables. 90C cable exist in both systems.
With a little work, you can work out tables but of course your tables will not be official.
An alternative solution is to use the tables from some metric code, e.g. the British. (Keep in mind that it's probably a bad idea to mix ampacities and derating factors from different codes.)
Bryan kindly posted a link to a conversion table. Please note that the values have been rounded to the nearest existing size. In this case, the AWG/KCMIL sizes have been rounded to the nearest larger metric size.
[ June 25, 2004, 09:39 AM: Message edited by: c-h ]
