Davebones
- North Of Tampa Fl
Have a Siemens JXD63B350 breaker . ( 350 amps ) I found one of the phases showing signs of heat and the insulation is slightly burnt back . The lug is a 2 hole as this is parallel feeds for each phase . One of the set screws is not tightening down so I wanted to replace the lug . I found only lugs that are rated for cable size 3/0 to 500 mcm . I know they make pin connectors to reduce the size of the cable but what about when the cable is too small for the lug ? The cable's to the breaker are parallel 2/0 per phase . ???
