mtnelectrical
- Essex, New Jersey
when you guys do some services.do you use split bolts or those multi tap connectors (ilsco or blackburn or similar) when you make the connections inside the trough? I will do a Upgrade and I wonder which way it has worked better for you guys. I am using a wire trough 6"x6"x48" then 3- 100 amps meter pans (that's how we call it here in Jersey) and then run to the basement.To use split bolt there would be a 2/0 copper and 3 - #4 per connection,the web site below just shows one connector for 3 connections we will need for 4 connections.Three would be needed (L1,L2 and Ground)
http://www.drillspot.com/products/44..._Tap_Connector
