lordofpi
- New Jersey
I just happened to be browsing around, and I came across this video for Wiremold 4000. In the video, it takes the electrician almost ten hours to install 5 receptacles?
I personally haven't had the displeasure of working with surface-mounted raceway often. Is this really what goes into all this? I mean, by time you did all this, you could have knocked out the drywall, ran fresh NM-B through the studs, installed the receptacles, patched the wall, and painted again! I know there are some of you out there who can give me a heads up. Is this video just exaggeration (it does seem that they purposely make what's happening seem convoluted)?
Also, any other tips on installing this Wiremold, et al.? As I always say, the more I continue to mock and hold something in disdain, the more likely it is I will be forced to use it at some point. :smile:
