I am confused now, i will make it clear question: i have a metallic column, inside the column i have to install different cables from different panel boards (one cable for lighting from panel board no.1 , one cable for a fan from panel board no.2 , and one cable for a motor from panel board no.3) all circuits with same operating voltage
please advice
Well, sort of. From that article, I infer that I can run a 208 volt three phase circuit and a 120 volt single phase circuit through the same raceway or into the same enclosure. But it does not say whether the two circuits do, or do not, have to originate from the same panelboard. On the other hand, it does allow me to run a 480 volt circuit and a 120 volt circuit through the same raceway or into the same enclosure, and those will certainly not originate from the same panelboard.. . . 300.3(C)(1) covers your question . . . .
