timmermeier
- alton il
- electrician
how small of wire can i staple to bottom of joist in basement ? ( 2011 nec art. please ) ???????????????????????????????????????????????????????
This in peticular I've seen amended in a few different areas to exclude crawll spaces but my goto in those is to staple to the side of a stemware even though it's not required where I'm at.334.15(C)............(C) In Unfinished Basements and Crawl Spaces. Where cable is run at angles with joists in unfinished basements and crawl spaces, it shall be permissible to secure cables not smaller than two 6 AWG or three 8 AWG conductors directly to the lower edges of the joists. Smaller cables shall be run either through bored holes in joists or on running boards.
Agree that wire is single conductor, but not all cables are multi-conductor. There are single conductor cables. Probably a better definition is that cables are meant to be run "as constructed" with no additional protection. Wires are not.Wire is single conductor(s)
Cable is multiple conductors
You need to be 2 inches atleast from the bottom of the joists for building code. I don't see any reason for nail plates thenMake sure to use nail plates if needed and for your piece of mind if your drilling studs.
But how does running through bored holes prevent someone from hanging something on it? Just eliminates the pulled stape problem, but can still stretch and damage the wire.Thus requiring running board for installation of cable crossing or running thru bored holes.
It's possible that hanging something can damage the cable but regardless of whether or not that will happen it is code compliant to run through bored holes.But how does running through bored holes prevent someone from hanging something on it? Just eliminates the pulled stape problem, but can still stretch and damage the wire.
He's just asking How the code makes any senseIt's possible that hanging something can damage the cable but regardless of whether or not that will happen it is code compliant to run through bored holes.
WHAT????????He's just asking How the code makes any sense
It doesn't
This is certainly anecdotal but when the rule only applied to basements I had an old time Code Panel member tell me the original intent of not allowing NM on basement ceiling joists was due to folks finishing the basement by adding cover directly to the joists nailing into the NM.But how does running through bored holes prevent someone from hanging something on it? Just eliminates the pulled stape problem, but can still stretch and damage the wire.
Seen it done. So statement has some validity.This is certainly anecdotal but when the rule only applied to basements I had an old time Code Panel member tell me the original intent of not allowing NM on basement ceiling joists was due to folks finishing the basement by adding cover directly to the joists nailing into the NM.
Take it with a grain of salt.
I've seen that done in attics many times where they just slapped some plywood on the joists.This is certainly anecdotal but when the rule only applied to basements I had an old time Code Panel member tell me the original intent of not allowing NM on basement ceiling joists was due to folks finishing the basement by adding cover directly to the joists nailing into the NM.
Is the same true for mc cable ?You've stated wire but did not say what type. Augie gave you NM cable but AC cable can be stapled in any size as long as there is a staple in every joist. {320.15}
for joist, it can be run on the underside where supported at each joist and not subject to physical damageIs the same true for mc cable ?
