An electrician installed a screw type compressor. 230Volt, 3-phase, 10HP name plate ratings stated 45Amp and 60Amp breaker. #6 wire was pulled from starter (in emt conduit) to disconnect switch. From disconnect switch to motor flexible conduit was used. The wires in the conduit run from the starter to the disconnect are vibrating. Nothing else is vibrating. You can see and feel the vibration at the starter and hear the wires banging in the conduit. This only happens at startup. Electrician checked loads and everything is within tolerances. The entire conduit run is less than 25 feet. Any suggetions on what to check?
