I've always wondered about the 360 degree requirement. I know it is sort of a one-size-fits-all rule, covering typical conduit lengths, and usually works as a guideline to keep you out of trouble when constructing conduit runs.
However, I would think that if the pulling metrics are low enough to indicate a "gentle pull", even with a lot more than 360 degrees worth of bends, I would think there would be no problem with building it, and having it work. What I mean by pulling metrics, is the tension and sidewall pressure. I'm sure you can come up with examples where one could in concept exceed the 360 degree rule, and still have a successful installation.
