Re: wiring 3P breaker for 2P circuit
so, a 3-pole breaker could be used: </font>
- <font size="2" face="Verdana, Helvetica, sans-serif">For 3 individual single pole circuits (3-pole Handel-tie optional!)</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">As a combination single pole and two-pole (3-pole breaker-tie OR Breaker-tie across the 2-pole circuit only)</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">As a 3-phase breaker (3 pole breaker-tie required)</font>
Hmmm, I guess as long as the breaker-tie is listed for use with that breaker, it's ok. I know I've seen ones rigged with #10 solid! Once I found (3) 2-pole breakers with all the ties removed & (2) 3" long 6/32's were both linking 3-poles together. They used (3) 2-pole breakers to make (2) 3-pole breakers!...worked great, but don't think it was up to code. Although the 6/32's did fit through the little holes in the switches quite nicely and they even used nuts on the ends!
If I was an inspector, I would have been tempted to let it pass!
Dave
