Jpflex
Electrician big leagues
- Victorville
- Electrician commercial and residential
My coworkers are having a problem with a transformer not putting enough volts out on the secondary.
I do not have further details from them but I was able take a small transformer and convert it to a buck and boost depending how I orientated the secondary while shunted to primary.
I used a small 9 volt battery for source and I was able to get the secondary to jump to 13 volts as I opened primary.
Besides voltage stress on transformer not designed for buck and boost I don’t understand all the benefits in a buck and boost transformers. Or in wiring a standard transformer to a buck and boost since transformers already step up voltage at primary.
Is it line voltage that is increasing in a boost where standard induction transformers only see transformation in secondary?
