Wiring a switch for my compressor
Jimgordup
New member
Beavercreek ohio
Well I will be installing a compressor I just purchased in my basement and want to wire it to my garage with some type of light switch to turn it on and off (I will have my hard piped air supply there). After doing some calculations I think I will need 8 gauge wire with a 45amp breaker it is 40 ft from my panel (see the attached picture of the motor specs). Now the question is can I use a 30amp toggle switch from homedepot to turn it on and off or would this not manage the amp load through it? I am looking for suggestions on how to do this. I would possibly like a switch in the basement too if I want to use the air supply down there, but if wiring a 3 way switch is too hard, then I just will turn on in garage and walk down to use. Thanks.
Little Bill
Tennessee NEC:2017
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the bottom left corner of the post.
