I was looking to wire a welder in a residential garage. The primary voltage is 230v at 131 amps. The homeowner does not need to use the welder at full power. Would it be fine to wire the welder with 100 amp overcurrent protection and #2 conductors which will handle the amperage?If the homeowner were to draw to much current it would trip the CB. The homeowner fully understands this. If it were a industrial place, I would obviously wire it at the max amperage. Is it safe to underrate the OC protection? Reason for not wirng this at max current is that there is only a 150 service.
