CopperTone
- MetroWest, MA
SO I have to wire an AC condenser tomorrow and wanted to be sure I was doing this correctly.
Name plate says " minimum circuit ampacity 27 amps minimun breaker size 40 amps"
So that means I am going to use a 2 pole 40 amp breaker with #12 wire to the disco and unit. #12 is good for 30 amp in the 90 degree c column in 310.16
That is right - right? just wanted to be sure.
thanks
thanks
