wiring assistance for low voltage thermostat for electric 240v heater
Saleencook
Louisville, KY
I have a profusion electric 240v heater and would like to wire in an external low voltage thermostat. I have the Aube RC840T-240 relay and not sure where to wire it in the circuit. Profusion manual only shows how to tie in a line voltage thermostat but not a low voltage thermostat.
So not sure if I need to bypass built in thermostat (unwire and cap off) or tie into existing thermostat but turn it up to high.
I’ve attached pics/wiring diagram of circuit.
If someone could draw / show me schematic of new wiring be easier to understand I believe then trying to write it would be of much help
Not sure these pics are any better
Not sure these pics are any better but really would like some assistance if I can email someone to help out much appreciative
Wire the low voltage stat to terminals R and W on the Aube unit
Does that Aube relay have the capacity for the heater you are using? Those are only good for 22 a , I think they make a bigger one.
