Wiring for oven and microwave
Littlewinguk
New User
UK
I have just bought two new appliances to replace existing oven and microwave both are Miele microwave is H6500bm k.w 3.3 volt230 amp 20 and the oven is H 6560 bp k.w. 3.7 volt 230 amp 20
problem is when we went to check our existing electrical connections we found out that they are wired to the same 32 a way on the circuit board and both have been connected through electrical plugs with 13 amp fuses!! Totally co fused as to what to do as the electrician we had round said its not right however the current appliances have the same k.w output and have worked perfectly fine for 8 years, my only concern would be the pyrolitic function. Can we run the oven into an unused spur ( change current socket over) and use a 13amp plug for the microwave? HELP please
I am closing this thread in accordance with forum rules. This forum is intended to assist electricians, electrical contractors, inspectors, engineers, and other members of the electrical profession. If you are not an electrician, we are not permitted to provide you with assistance with your home’s electrical installation issues.
