dahualin said:
Is EMT 1-hour fire rated? Do I have to use MI cable for this application?
I do not beleive that any wiring method has a fire rating...???? The construction around it would have a fire rating in most cases.
Not a "FIRE" expert, but one would think that a "smoke" exaust fan would not be run perpetually as would a fire pump would be a means to put out the fire, and would need to be run to the bitter end as required by the code you mentioned. A "smoke" exaust being fully invloved in fire would only aid the fire, as a means of travel after it finished exausting the "smoke"... One might want it on with a fire in the area, but not to continue while on fire inifinately.
What is this "Smoke Exaust Fan" for?
Most that I have installed have been fine with using whatever wiring method allowed in the building type. Often EMT/MC... Where I am all FA systems are in EMT, but the fans are not 'part' of the alarm system. The duct detectors would be...
