Hello folks,
First of all, i would like to say that this forum is probably the best online resource for electrical questions and a big thank you to all those people who take time out if their busy schedules to answer questions.
Now to the issue at hand, I have a 2 HP sump pump that is being installed at the project site. The selection of the pump has not been finalized and depends on the answer to this electrical question. The existing panelboard that will feed this sump pump is a 120/208Y. There is a 2 pole 30A circuit breaker that is available to feed the sump pump.
What should the voltage requirement be for selecting the pump? Does the pump have to be single phase 240V? Correct me if i am wrong, but won't the phase to phase voltage be 208V if two breakers are feeding it from a 120/208Y panel. The wiring from the existing breakers have been already pulled in conduit and left for final connection at the sump pump location.
