- Tennessee NEC:2017
- Semi-Retired Electrician
An electrician friend asked me to help with wiring an addition to a building. It is a slaughter house and the area will have metal walls but could be subject to wash down.
Some questions:
Would the wiring have to be wet rated if not exposed but behind a metal wall. The wall, as I understand it, is just corrugated metal panels. Not sure if there will be any sealant at the seams or not.
Builder asked that the receptacles be "adjustable". Not adjustable in the normal fashion as in adj boxes that can be run in/out, but he wants them to be able to be moved to hit a flat spot on the metal panels and not on a ribbed section.
How would you do something like this?
Only thing I could think of was to leave wiring in the wall and cut-in boxes where flat spots were. Problem with that is the boxes would have no support to speak of. A pop-in box wouldn't hold very tight on this metal. Any ideas on how to leave the boxes & wiring to mount when the panels are in? Or other ideas about this?
Some questions:
