There's alot of other threads on this issue but I'd say it's never going to be the issue people think it is and I personally think compression fittings have more installer error.Maybe with compression fittings, definitely not set screws, his reason is what if you forget to tighten down the set screws? Which I can kind if agree with. We'd have to pull some kind of EGC in that pipe and bond the box.
Again that's not required by the NEC so either there has to be a local code amendment to make it a requirement or the inspector is just making up his own code.Maybe with compression fittings, definitely not set screws, his reason is what if you forget to tighten down the set screws? Which I can kind if agree with. We'd have to pull some kind of EGC in that pipe and bond the box.
Oh boy, here we go again.....what if what if what if....Maybe with compression fittings, definitely not set screws, his reason is what if you forget to tighten down the set screws? Which I can kind if agree with. We'd have to pull some kind of EGC in that pipe and bond the box.
A fault is going to clear just fine even with some loose set screws. I love how for some reason in these discussions the wire EGC is always exempt from ever having bad workmanship, improper installation, untightened screws, etc.what if you forget to tighten down the set screws?
