Krusscher
- Washington State
- Electrician
Coming from Industrial I didn't deal to much with commercial wiring.
1. I have to run a 50 amp 4 wire circuit down a hall above ceiling grid about 60 feet and to box outside. I am still unsure if it needs to be fire rated but it is not a plenum and there is quite a bit of MC running around up there. What would be my best flexible wiring method to achieve this?
2. I do have to go through some walls so I am assuming where I do that I need to set a box and run emt to the other side to another box?
3. None of the current penetrations have fire caulk around them so I am assuming I won't have to do that either?
