Wiring method for LED tape lights
marmathsen
Seattle, Washington ...ish
Electrical Contractor
Just curious what type of wire you all use to feed between transformers and LED tape light. I'm referring to under cabinet lights in a residence although curious what the practice is in commercial if different.
We've always used 18/2 thermostat wire but curious if others use something different.
Rob
I use in-wall speaker cable.
As for size, it depends on the install (length of cables, wattage of ribbon sections). I run a separate cable from driver to each ribbon section.
18-gauge is good for 2 amps at a maximum of about 30 feet. Otherwise you can have enough voltage drop that it starts to affect brightness.
Note that voltsge drop is significantly more important at 12 volts
I once installed some 8-amp ribbons that were high on a deck, while the transformer was below. I ran 12-gauge cable for those.
