tallgirl
- Glendale, WI
- Controls Systems firmware engineer
I'm just about finished my little guidebook and I'm trying to illustrate a point about the 6' requirement and how that might make one have to run wires in a less than direct manner. The example I've come up with is where the wall is laid out door-window-corner and the distance from the door to the corner is 5', making it so the outlet must be on that wall (since there is going to be no stud in a reasonable place to mount the box), but the only reasonable place to mount the box is on the stud which is part of the window frame.
I was taught to never, ever run Romex straight up a stud that's part of the framing lumber for a window because people like to drill holes for drapery mounting hardware and the odds that some idiot was going to hit the nicely stapled to the stud wire was too great. So, I'd staple the wire about a foot up from the box, traverse diagonally to the next stud, staple, then straight up the second stud, penetrate the ceiling plate, and get on with life.
If I put this in my little booklet I'm not going to have some electrician tell these peeps they are wasting their time, correct? The electrician is going to pat them on their head and thank them for watching out for future drill bits, correct? Or was I taught wrong? Caveat driller?
Here's a graphic from this website. Note that I'm not asking about the 1 1/4" requirement, I'm asking about common practice. Obviously, the wire would have to be more than 1 1/4" from the face of the stud.
(Added piccies ...)
(Added piccies ...)
