apprntice
- Modesto, CA
?My brother built a covered picnic area in his backyard about 10 feet away from the house and he wants to install 4 lights, 1 fan and a pair of duplex receptacles. Now, he wants to take power from the closest outside receptacle (gfci) fed from a 15A breaker wich also feeds general use receptacles in the living room (only one duplex rec. is being used) and one outside light. Given my close to zero residential experience i need some help figuring this out.
First, i rather run a new circuit from the panel, but, if it's legal to feed from the duplex i'll do it since is cheaper.
I'm planning on using either 14-2 or 12-2 UF cable for everything since is allowed for wet locations and underground installation (down 24" or 16" if in a raceway) . I know that i need gfci protection but that's already covered. What i don't know is how to come off the wall and across, since there is some sort of sidewalk around the house.
I was thinking in a weatherproof junction box on the wall underneath the gfci, then ? or 1?? pvc along the house to where i need to come across and then i don't know if run it underground and the come back up to another box; or run it all aboveground.
I will try to get some pictures but In the mean time any ideas, suggestions, comments, code violations, etc?
