Bjenks
- East Coast of FL
Polling question:
When you see an engineer specify a recirculating pump for a hot water heater (electric 120g or less), do typically connect it to a receptacle/power circuit or do you run a neutral with the water heater and connect it to one of the phases on the secondary of the disconnect? I usually specify the first solution, but notice a lot of the installers bypass that and do it the second method unless the inspector makes him do it my way. I am not sure if one way is better than the other either.
