Alwayslearningelec
- NJ
- Estimator
Very basic here but would like input
So if a neutral is required at the switch because your not using a raceway or can't access the switch to pull a neutral in the future would you run wiring like this? See pic( bad drawing). My main question is getting power/neutral to each switch.
So you have (2) 1x4 in each room with a switch all on same circuit.
1. You would have to(should) daisy chain the power(red line) from the panel/source in/out of each switch?
2. Then obviously you'd have switch leg(not a loop) up to each light box.
